Hi guys,
I have recently purchased a GTX 650 but little did I know, I don't actually have a 6 pin connector coming from my PSU to hook it up. I know I should of checked before but I didn't and I'm looking for a solution. I have looked into using a "2 x 4 pin molex adaptor cable" but I dont think my PSU has any spare molex connectors either? I know I can take out the one for my LEDs (not that necesarry) but I was under the impression that you needed to connect both the cables.
Here is a picture of the molex adaptor i'm thinking of buying:
Here is also a picture of inside my PC (and what I think is a molex?) :
Also here is a list of my PC specs:
AMD A8 6600K Quad Core Processor / CPU running at 3.9GHz (With 4.2GHz Turbo Mode!)
8GB DDR3 1600Mhz RAM
1TB SEAGATE Barracuda 7200RPM SATA Hard Drive With 64MB Cache
SAMSUNG 24X DVD / CD - RW Dual Layer Optical Disc Drive
MSI FM2-A55M-E35 uATX Motherboard
500W Quiet Power Supply Featuring Large 120mm Cooling Fan
High Quality Vantage RED Desktop PC Gaming Case with 3 x 120mm RED LED Cooling Fans.
SD Memory Card Reader Built Into Top of Case
Gigabit Ethernet 10/100/1000 Mbps LAN
6 X High Speed USB 2.0 Ports on Back Plus Further 2 On Top
8 Channel HD Audio
6 X SATA II 3GB/s Ports
1 X PCI Express X16 Slot
1 X PCI Express X1 Slot
1 X PCI Slot
2 X PS/2 Port (For Keyboard / Mouse)
1 X VGA Port
1 X DVI Port
1 X HDMI Port (With Audio)
8 Channel HD Audio
1 X PCI Slot
1 X VGA Port
1 X DVI Port
