D dombelcher5 Commendable Jun 15, 2016 3 0 1,510 Jun 15, 2016 #1 My REALTEK 11n USB Wireless says it's disabled even though I've downloaded all the drivers and plugged in the USB stick. I don't know a lot about PC's so help is appreciated .
Saga Lout Retired Mod Mar 31, 2010 24,042 310 69,740 Jun 15, 2016 #2 Go into Control Panel>Device Manager and right click the device. Look at the Properties to see if it is Enabled and to check the drivers are correct. Upvote 0 Downvote
D dombelcher5 Commendable Jun 15, 2016 3 0 1,510 Jun 15, 2016 #3 Yes, everything is enabled also , the drivers are correct. Upvote 0 Downvote
Saga Lout Retired Mod Mar 31, 2010 24,042 310 69,740 Jun 15, 2016 #4 When you remove it from the USB port, do you hear the de-donk sound? Upvote 0 Downvote
D dombelcher5 Commendable Jun 15, 2016 3 0 1,510 Jun 15, 2016 #5 I do not hear a sound but my pc recognises that the USB has a been taken out. Upvote 0 Downvote
