I noticed this thing where on some boots, my computer wouldn't get past the bios screen. Instead of getting into windows, the monitors would go black and say no signal. My solution to this was to power off the computer with the power button and try again couple times and it worked almost every time on the third try.
One time, when the monitors went black and I restarted my monitor, I got into windows, but the computer was using the basic display drivers with the resolution locked to something very low and after a minute the whole computer froze so I had to power it off.
After that I realized that, if I start the computer without any monitors plugged in and plug them later, the computer boots normally.
Also, after switching out the rx 6800 for a gtx 1080, the problem stopped happening.
I've used DDU to reinstall gpu drivers and have formated my drives while reinstalling windows, but it didn't help.
I've tried using one and two monitors, with display port and HDMI cables, without any luck.
I've reset the BIOS into factory settings, but haven't reset the CMOS.
I've also tried older and newer BIOS firmware.
Could the problem be software related or is the card the problem?
