Question my samsung 850 ssd caused incompatibilities problems with my actual machine
maillet
313
8
18,785
Hi. Was planing to buy a new ssd since my current one causes problems with my actulal machine. they say the rapid mode cant function due to incompatibilities. i'm running with a ryzen 2700x, x470 aorus ultra gaming, gtx 1080, corsair vengeance LPX 16Gb 2933Mhz
on windows 10 pro
the ultimate question is: will a samsung 860 ssd cause such problems? thank you
I would rather find out if your current problem can be fixed. I'm assuming that when you're experiencing problems with the 850, you'll probably have the same problems with the 860, as most of it is identical. Does it give you any info in Samsung Magician as to why RAPID mode can't function?
