[SOLVED] My samsung 980 pro wont show up on samsung magician
Jul 6, 2021
I bought a new 980 pro and ive installed the latest bios on my Gigabyte motherboard, but it wont show up on samsung magican, my bios and windows 10 registers it but nothing also tried booting a fresh windows install on it also using csm support but i just get a black screen with the typing symbol, its on achi mode and its also been formatted as a gpt, also its in my PCIe 4.0 slot
you not only one seeing nothing from Magician on a Pro this year
https://us.community.samsung.com/t5...compatible-with-Samsung-Magician/td-p/1805810
does it work otherwise?
do you have RAID mode on in bios?
Yeah ive tried it in RAID mode
Got the 980 firmware installed too, still nothing
is the only problem it won't work with magician?
might be a bug with newest version of software. i only show this as its been used here elsewhere, i don't normally like 3rd party sites - https://www.filehorse.com/download-samsung-magician/old-versions/
I can use it as simple storage but i want to put windows on it, so i tried samsung data migration but it wouldnt show up there either.
So i installed windows 10 on it and tried booting it but it wouldnt show as a boot drive unless i had csm support on, so i booted it with that but i just get the black screen
ahh, i thought it was just magician that wouldn't work.
so what happens if you try to install in UEFI boot?
AHCI doesn't apply to NVME
what motherboard do you have?
are you using boot override to boot the USB?
it might not make any difference
whats boot order? usb doesn't need to be in it, shouldn't really have anything in it yet since nvme is blank
on the save & exit screen of bios is a choice
Boot override
if you pick USB from here pc should restart and boot off the USB
(I have an Aorus X570, it has similar bios choices)
you shouldn't just get a black screen booting off the USB. NVME is blank (i assume) so it won't boot off it yet.
sure installer is okay?
Boot override
Installer seems fine
