Question My second monitor worked yesterday but not today ?
Aug 17, 2023
4
My GPU is Nvida Geforce GTX 1650 Super
A few days ago i bought a new HDMI cable to use an old TV as a second monitor on my pc, only to discover that my GPU only has 1 x HDMI port (already used by my monitor) and 3 x DisplayPorts.
So i went later and bought an HDMI-to-DisplayPort adapter and the first day all went well and i could use both my monitor and the tv at the same time.
However, when I turned my pc on the next day, only my main monitor had display and now my monitor only has display if i plug it on the first DisplayPort with the adapter. If i plug it in the HDMI port or any other DisplayPort, it doesnt give display after the bios screen.
The TV doesnt work as a display even when plugged in the first DisplayPort or plugging the HDMI cable in to another slot on the TV. The new HDMI cable works well, i have tried it.
Things that I have tried:
  • Removing CMOS battery and restarting
  • Starting the pc without the GPU, shutdown the pc and then connect the GPU
  • On device manager, uninstall device on the GPU and the monitors (even those that appear hidden)
  • Unninstall all display drivers using DDU
It could just be that the ports on the GPU don't work, but the TV should work as a display when it's plugged in the same place as the monitor was.
Any help is appreciated and thank you beforehand.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Apologies for not including my hardware specs.
Motherboard: Gibabyte Technology H410M H V3
BIOS Version: American Megatrends International, LLC. F1, 24/5/2021
CPU: Intel(R) Core(TM) i3-10100F CPU @ 3.60GHz 3.60 GHz
CPU cooler: Factory Intel Cooler
GPU: Nvidia Geforce GTX 1650 Super 4gb
RAM: 16GB
SSD: Windows Installed on a SSD kingston 250gb
HDD: Seagate 1TB
PSU: XT Series 650w, around 6 months old
Chassis: Eros Xigmatek
OS: Windows 10
Monitor: Samsung S22D300
TV (second monitor): Hisense Model: HLE321RT, 32 inch
