My USB 3.0 External HD is running faster than my Internal SATA III HD
RyanTScott
128
Just curious why this might be. Any thoughts? CrystalMark below:
Internal SATA III
Read:92MB/s, Write:88MB/s
External USB 3.0
Read:146MB/s, Write:145MB/s
That 1TB drive is 10 years old, its areal density (density of data on the disk) is much less than on that 4TB drive, one rotation of the drive will cover much less data than a modern 1TB drive. A modern 8TB 5400RPM drive will sit around 220MB/s of sequential performance on the outer tracks and 160ish on the inner tracks (assuming it is not an archive drive), although its random IOPs will suck compared to 7.2k RPM.
Note that HDDs are way faster at the beginning of the disk. Contrary to optical media, HDD start is at the outer edge of the disk. Just check the read/write performance of any spinning media.
This kind of test should be done on the whole disk while they are empty and not being used as a system drive.
