J Justsun Oct 9, 2019 4 0 10 Oct 9, 2019 #1 While it still appear in disk management i cant access my usb drive at all. It appears as full capacity while i still had several files on it. I wanted to know if its possible to recover the files from it in any way possible.
popatim Titan Moderator Dec 2, 2009 39,129 1,040 136,890 Oct 9, 2019 #2 See if Recuva or Photorec can access & recover them. Upvote 0 Downvote
J Justsun Oct 9, 2019 4 0 10 Oct 9, 2019 #3 popatim said: See if Recuva or Photorec can access & recover them. Click to expand... Recuva can't even access it. It asks to format before using it. Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,719 4,812 126,640 Oct 9, 2019 #4 Try with getdataback. https://www.runtime.org/data-recovery-software.htm Upvote 0 Downvote
J Justsun Oct 9, 2019 4 0 10 Oct 9, 2019 #5 SkyNetRising said: Try with getdataback. https://www.runtime.org/data-recovery-software.htm Click to expand... Didn't work either Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,719 4,812 126,640 Oct 9, 2019 #6 What error did you get? Can you show screenshot from Disk Management? Upvote 0 Downvote
J Justsun Oct 9, 2019 4 0 10 Oct 9, 2019 #7 Screenshot from Disk Management and from the program after using it in my usb drive Upvote 0 Downvote
