MyDigitalSSD BP5e Low-Cost TLC SSD Review
  • Thread starter Thread starter Guest
  • Start date Start date
That price is incredible. I remember my first SSD, when it was ONLY 2$/GB. If I was buying today, I'd get 6 * 480 GB drives, and run them in a btrfs raid, just for plain storage. For anyone buying today, for their own use, it makes no sense to go mechanical.
Can't wait for the next generation Samsung 3d nand.
It makes no sense to raid 0 SSD's, you won't improve random 4k performance AND YOU WONT IMPROVE LATENCY (wich is what it makes SSDs faster than a HDD). You're simply adding more fail %.
NVMe SSD's barely improve those things. We will need intel's 3D Xpoint (or similar tech) for another massive gain in those things.
The price might be relatively good for an SSD, but that's still 25 cents per gigabyte. Mechanical desktop drives, by comparison, are generally around 3 to 5 cents per gigabyte, which for someone needing multiple terabytes for bulk storage or backup redundancy can really add up. For many purposes like storing video, there won't be much of a performance difference either.
Of course, most people probably don't even need 1 TB of storage in their system, and 240 GB of storage could be more than enough for them, in which case doing away with a mechanical drive in favor of a comparably priced but lower-capacity SSD could make a lot more sense.
Interesting to see TLC continuing to lead the value market with further refinement of error correction technique while still developing improvements in performance.
As a REVIEW, it comes up short in evaluting against products in the same performance and price segment. As I started to read the review, I kept looking for Tom's Best Pick 1TB Budget Buy, the Mushkin Reactor, to be included. And, there are also other TLC based drives, that Tom's has reviewed in other capacities, that should be included. In my mind, the review should have included at a minimum: Samsung 850 EVO 1 TB (as the TLC performance reference), ADATA SP550 960GB, and Mushkin Reactor 1TB. At this point in time, the MyDigitalSSD, ADATA and Mushkin drives are competing at the same price point on Amazon and Newegg. Comparing these drives would have brought more meaning to the review.
Nintendork,
There are reasons to RAID0 an SSD. For example, working with video can benefit. Plenty of articles with number to prove that, and also to prove that for MOST things real-world benefits aren't there.
How likely is it that other Phison S10 drives have benefited significantly from performance-related firmware updates since release? It seems like this drive is better than the competition primarily because of the more mature firmware, but I'm wondering if other drives have also improved since release.
When Adata released the SP550 drives for review the 960GB model was not ready. We simply do not have that drive. We built a low cost SSD performance database for each of the other capacity sizes and you see similar products grouped together in those reviews. From Computex (last June) until only recently many of the TLC-based drives were not available. In short, we're working on it.
This review was put together before the OCZ Trion 150 arrived, the two new PNY drives, the new Corsair LE and the stuff we can't talk about yet (but soon).
The Best of Monthly (what I call it) goes back to being a monthly release starting this week. Several of you read and comment on my reviews so you are here quite a bit. I plan to utilize the monthly column to recap the reviews for the month and give some insight into what to expect for the next month. I've also added several new columns. Expect to see entry-level, mainstream, and premium drives for each capacity as well as new PCIe and All-in-One RAID drives.
Minimal price reduction for a massive reduction in write endurance. It is a bad value unless they can reduce their price by at at least 40% (to match the data density gains that they get from TLC).
Even though - good job! The review is useful and one gets a nice overall view. Thank you. :)
May I ask for your personal opinion? As a budget 1TB SSD - would you buy Mushkin Reactor 1TB, MyDigitalSSD BP5e 960GB, Adata SP550 960Gb, or wait for new releases (or wait even until june)?
I hope "mydigitalssd" has finally gotten their stuff together. I bought a BP4e mSATA drive about a year or so ago. It failed constantly. I contacted "mydigitalssd", RMAed the drive. MDSSD replaced the drive. The replacement drive has the same issues.
There is a cost/benefit that needs to be taken into account when dealing with drives. This is a low cost option,however do you really want to take the chance? I am sorry i did.
I have a brand new BP5e M.2 NGFF drive and my Asus 970 Pro Gaming / Aura does not recognize it. It does not see it in the BIOS. I have already flashed the Asus System Board BIOS. So, now what?
I recently installed to BP5e series drives in my venerable 2008/9 MacBookPro, based in large part on the recommendations found here at Toms Hardware.
I'm provisionally satisfied with the upgrade.
Several factors entered into the decision: My existing internal drive was both nearing capacity with legacy data and old enough I was starting to worry about the longevity of the disk surface. I do a lot of disk I/O during my daily workflow as I serve the websites I develop to myself locally and local storage I/O rates was the last link in overall system performance I could improve. And I'm capable of doing my own research and support.
I replaced my internal 750GB Western Digital drive with a 480GB BP5e formatted with two partitions so I could dual OS boot the computer. I then replaced the optical drive with one 960GB BP5e in an OWC Data Doubler caddy to hold the work files.
I had to pay a lot of attention to partition alignment issues and had to install TrimEnabler to get the Mac OS to use TRIM on third party drives. These two issues dealt with, I feel I will get optimum performance and wear balancing over time. A given Boot Partition is about half full with 128GB of data on a 239GB partition, so the drive firmware can move files around as needs be.
I've got more free space left over on my work disk than I had in total, so there is plenty of room for new projects.
One of the disappointments is that the MBP uses a NVidia MCP79 SATA controller, which is notorious for issues. The best it can do is SATA II and I was willing to live with that on the principle that the next upgrade would be to the system itself. A 2012 MBP would buy me ~32GB ram, more processor cores and SATA III speed, so I'm basically setting up for that system when I can afford it.
However the work drive in the former optical bay ends up negotiating a link speed of SATA I, so I am running the drive there at 1/4 its capability. I have sent a note to MyDigitalSSD tech support asking them to work with Apple and arrange for that negotiation to end up at SATA II, but thus far no reply.
I am doing a poor-man's raid by keeping my zillions of website HTML, PHP, CSS and JS files on the external drive and the Database Server, Webserver and PHP language files on the boot drive, so both interfaces get used to deliver a web page.
Thus far, web page delivery, while not instantaneous, is much quicker overall and boot time is down to the order of one minute.
Ask me in a couple of years if going the low cost, low performance value drive was the right option.
To get the most out of these drives in the long run, you have to pay attention to proper partition alignment and TRIM enabling, particularly on Mac OS X.
The upgrade made sense to me and thus far has worked out.
Your milage may vary.
BTW if someone has an email address or contact for MyDigitalSSD tech support, I have a firmware update request to send them.
Thus far, no reply to the level 1 tech that has responded to my questions about partition alignment.
