[SOLVED] Mystic Light software for MSI Z390 Edge AC
Dec 31, 2018
Hello. Every time I download Mystic Light from MSI, I always get an error that there is no file. I can find other software for Mystic Light, but they do not support my chipset. Where can I find a download that is compatible with my motherboard?
what SR-71 said X2
after you download it, right clik on it - one of the choices near the top of the list will be "extract"
choose that and you're good to go. Whenever you see a file with a zipper on it, it's a zip file, and needs to be extracted
i just installed last night
