NAS drive decision help
Tamikanottammy
168
Which of these if any can a) be used as a network attached external hard drive and/or b) use ntfs format as the drive format? Preferably looking for a.
Dlink dns 321 nas
Buffalo terastation
Ht h0 6tgl r5
Or
Iomega nas200d
Not looking for any other suggestions JUST THESE NO ALTERNATIVES PLEASE
Not sure what your question is:
All three devices are identified as NAS devices and should work if plugged into a router port and configured (via the applicable User Guide/Manual) to join your network.
Would expect that you will need to assign a static IP to the NAS via the router and the NAS's MAC.
If you are asking which NAS would be best then you need to provide more information about your requirements and what you expect the NAS to be doing.
E.g., serve as site for system and data backups, store documents, video files.
Factors being drive performance, read/write speeds, capacity.....
The other factors: cost/budget, size.
For network folders, NTFS does not make sense, as long as the "server" obeys access control rules. Most (all?) NASes on the market use Linux as underlying OS, and you won't see NTFS-formatted drive there.
If your goal is to ensure you would be able to attach the disk to your computer in case NAS goes belly up - there are Windows utilities for access to Linux file systems.
Understood.
The DNS-321 IS a NAS device, thus it can be used as such.
In addition to prior replies by others, please be aware that while the DNS 3xx NAS devices from Dlink have a good history, Dlink is exiting the market. You will still be able to buy some new ones, but essentially Dlink isn't investing in them anymore.
That being said, I've been running 3 sets of the 3xx's for a number of years now without any issue. (Made sure I picked quality drives so no drive failures either).
