NEC EA244UHD 24-Inch Ultra HD Monitor Review
Agree with alidan, at this density, pixels are wasted: you don't see more as you need to scale everything up.
And, knowing the hardware you need to drive this resolution,, I don't see any interest except for some niches.
You need at least 44'' to exploit 4K.
The problem with these high-DPI screens is that support for these displays is lacking in many modern OS's. Yes, support is getting better, as with Windows 8.1 and its better UI scaling, but even with good support in the OS's UI, you're still at the mercy of the apps you use, and many are terrible when it comes to high DPI, with some even failing to work properly.
Retina is only useful when your programs provide good support for it. Otherwise it's just an annoyance. As an owner of a Yoga 2 Pro (13" 3200x1800), I can speak to this. I normally run my laptop in an upscaled 1920x1080 just to keep compatability.
@vincent67
So what about tablets and phones using UHD or 4k in the future?
The Pixel Chromebook looks quite pretty with its 12" screen and 2560x1700 resolution. That's a small laptop, but moving in the right direction I think!
yeah, i cant imagine widespread pc 4k adoption until we have video cards that can run it. i mean, we're still struggling with 2560x1440 resolution. there needs to be a massive improvement in gpu power in the next year
@atwspoon
Of course, I also found these extra pixels, above 1920*1080, for tiny screens from phones or tablets superfluous and no less wasted! Everything is scaled up so you don't see more stuff!
This is similar to digital cameras where the resolution becomes useless passed a certain point.
"Agree with alidan, at this density, pixels are wasted: you don't see more as you need to scale everything up.
You need at least 44'' to exploit 4K. "
While true of a TV at normal viewing distance. This is complete and utter BS for a desktop monitor. My eyesight is not that great and i can easily see the pixels(if i look for them) on the 1920x1080 monitor im staring at as i type this.
The move to 3840 cant happen soon enough. If i had a spare 1,400 id be all over this monitor. But i dont, i have to wait till the price comes down. Also wait for the refresh rate to go up, 60 is too low.
185ppi will be hard to see unless you really try hard. But sub 100 its pretty easy to see the pixels. The desktop world has been stuck with 90-110ppi for FAR FAR too long.
As for scaling, apps designed for 1980 scale perfectly to 3840, you just double everything. The the image will look identical to what you have now.
Granted there are some issues, like the windows app notification message that tells apps when they are being scaled. And some apps ignoring this message and telling windows back that it can handle the resoultion properly when it cant. Thats an issue. But for every app that doesnt cheat like that, and just renders itself, you can scale it easily.
Its the wierd ppi monitors that have problems scaling. You cant scale an image designed for 90ppi to 150 without screwing up the image. You can scale 90 to 180 easily and it will look perfect.
As far as games go. Just turn down the AA setting, and you achieve the same framerate with a better image on 4k then you do on 2k. With AA on youa re already rendering at the higher pixel density, then downscaling it to be displayed. Downscaling takes processing power, turn off the AA and its the same thing only faster. AA becomes unnecessary once you increase pixel density.
I am interested in further explanation of the Vincent67's assertion that digital camera resolution becomes useless.
Like none12345 mentioned above, it is totally dependent upon the intended usage of the product.
4K computer monitors are being viewed at extremely short distances.
If a photographer wants to produce very large prints from a digital image, resolution becomes paramount.
So, while there is certainly a point where the cost of increasing resolution capability becomes inverse to the need of a "typical" use, that point will not be the same for someone utilizing those higher resolutions for atypical applications.
IMO, smaller 4K displays still provide a ton of utility. Whether or not that utility is something a typical user would benefit from is largely irrelevant when one considers that a typical user is not going to be in the market for a $1300 computer monitor.
