Need $200-$300 Build
rebirthxken
39
Approximate Purchase Date: e.g.: this week (the closer the better)
Budget Range: 200-300 after rebates and shipping
System Usage from Most to Least Important: Gaming, Browsing, Downloading
Are you buying a monitor: No
Parts to Upgrade: New Build
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg
Parts Preferences: by brand or type: AMD or Intel
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1280x720 or 1920x1080,
Additional Comments: Can do max settings for Dota 2 / League of Legends
And Most Importantly, Why Are You Upgrading: New Build
This is probably the cheapest build possible that wouldn't be terrible at gaming. It would be decent at 720p, and mediocre at best at 1080p. $27 more would get you a higher performing A10.
CPU: AMD A8-7600 3.1GHz Quad-Core Processor ($77.89 @ OutletPC)
Motherboard: ASRock FM2A88M PRO3+ Micro ATX FM2+ Motherboard ($52.38 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-2133 Memory ($39.88 @ OutletPC)
Storage: Western Digital Caviar Blue 250GB 3.5" 7200RPM Internal Hard Drive ($23.50 @ Amazon)
Case: Xigmatek Spirit M MicroATX Mini Tower Case ($25.98 @ Newegg)
Power Supply: Antec 450W ATX Power Supply ($32.99 @ SuperBiiz)
Total: $252.62
Generated by PCPartPicker 2016-02-13 01:43 EST-0500
This would be much better for a little more than $300
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($72.89 @ OutletPC)
Motherboard: ASRock FM2A68M-DG3+ Micro ATX FM2+ Motherboard ($44.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card ($99.99 @ Newegg)
Total: $335.33
Generated by PCPartPicker 2016-02-13 01:48 EST-0500
