Need 500W Power supply to push GeForce GTX 1080 Card
jontramos
Hello! At work I have several Dell Precision 3620 workstations that I would like to upgrade the graphics cards to GeForce GTX 1080, which will help our designers with 3D rendering. I have come to learn that those cards require a 500Watt power supply, but the Dell Precision 3620 towers only have 365W PSU.
I was planning on upgrading the PSU to 500+Watt, but I am being told by Dell that they do not make one that will work with this case. And I am reading on forums that this model Dell has proprietary power connectors...
Does anyone have any advice on how to upgrade the PSU? Or am I out of luck?
Thanks in advance,
Jon
Urgh, then that's going to be a problem getting a GTX 1070 in. I checked directly on a couple of sites (Gigabyte & EVGA), & even the mini single-fan versions meant for ITX builds all required an 8-pin PCIe cable.
So it's looking like the most powerful GPU you can put into the system, without replacing the PSU, is going to be a GTX 1060.
