[SOLVED] Need a bit of help with fan configuration :/
Oct 15, 2020
Hi there, I'm in the process of getting parts for my first PC build and I'm not sure how I should really configure my fans..
This is my parts list so far: https://pcpartpicker.com/list/hM9dCz
The case has 3 stock fans, 2 on the front and 1 on the back and I wanted to buy a Corsair h150i liquid cooler, I'm not really sure where the best place would be to install the radiator, either the top or at the front :/ I'd appreciate any advice, thanks for helping!
The ideal location for that AIO on that case, should be the top.
It will also prolong the life of the AIO and a it will have a quieter pump.
Reactions: Phantom12B
Latest posts
