Need A Case To Fit Crosshair V and H100i
sethmac82
14
Looking for a different case to fit my Crosshair V Formula with Corsair H100i on top. Currently i have the Apevia sniper 2 and cant fit rad with fans attached. Ive seen where people have put rad on inside and fans on outside but im looking to keep it all internal. Looking to spend under $100. Any help would be appreciated. I dont know if psu info is needed too but i have Corsair HX 750
There are many options for this:
Fractal Design Define R4: http://pcpartpicker.com/part/fractal-design-case-fdcadefr4bl
NZXT Phantom 410: http://pcpartpicker.com/part/nzxt-case-caph410b1
Corsair 400R: http://pcpartpicker.com/part/corsair-case-400r
Corsair 550D: http://pcpartpicker.com/part/corsair-case-550d
The Define R4 and Phantom 410 are both excellent cases for the price.
The 400R may not be as good as the Define R4 or Phantom 410, but it's also slightly cheaper.
The 550D is a more higher quality case than any of these, but at a more premium price tag.
All of these are good, just go with whichever you think looks better.
