Need a cooling fan?
Vadamo
318
I used to have a Foxconn fan in my case , it was a 92mm(foxconn pv902512pspf oj). I am looking for a Red LED fan. Also I am curious if the fan comes with screws for the case because my old fan was held into the case with these rubber things. The wire needs to be long enough to reach my mobo(about 10 inchs or more.)
Thanks
You can buy a Cooler Master LED fan. They have many choices of LED colours. Yes, they'll come with screws. Be sure to ask your store about the thick screws.
