Need a cpu cooler for Xeon e5-2630 v3
Then look at the SNK-P0050AP4, a good sized sink with a large fan will keep the noise down. But the socket is a standard 2011v3, so any cooler for that socket will work, as long as it can handle an 85W TDP.
I would look at coolers that push the air down rather than towards the back, or the second CPU will be dealing with the first CPU's waste heat.
Yes specifically the X10dal-I-o. Running it in a full tower case.
