Need a help ASAP! Gaming pc without HDD!
BrokenCarr00t
70
So i just need to order parts i decided for my pc. But the thing is that i dont have enough money.So i decided to keep out HDD from my pc build and buy it next month instead. I have left my SSD samsung evo 120gb from my old laptop , so i want to put that in my new pc.
My question is , what are disadvantages when only using 120gb on powerful pc? I know 120gb its almost nothing but i only plaining to have windows 8 ,1-2 games( dying light and far cry 4) , after effect and adobe illustrator.
Also would like you to give me opinion on my rig
MOBO - GIGABYTE GA-Z97X-SLI LGA 1150
CPU - i5 4690K
GPU - MSI Gtx 970 4gb OC
RAM - Corsair Vengeance 2x4GB 1600MHZ
PSU - Corsair CX600
CASE - NZXT S340 White
SSD - Samsung Evo 120GB
You just have limited space, it won't affect the performance, but if you can't afford a HDD to go with this build you probably shouldn't be spending what money you do have on a PC.
Well im plaining on getting HDD next month. But what your opinion on pc rig? I was thinking on future update when building this , for example one more gtx 970 after 1-2 years
Yea but in my country it does not cost only 49 dollars 🙁
Anyway , what you think about this pc?
The build looks solid to me. Since you already ordered the parts it's probably a little too late to swap out the PSU, I say this because your interested in SLI in the future and the 600W PSU you selected might not have enough juice to power every thing. You probably won't need to upgrade to a second 970 for at least a couple years though.
