Need a help
8 gb ram is enough to play games on ultra so that shouldn't be a problem...
Yes that's correct and Msi really is a trustworthy brand. I don't think you will be having any problem with it.
I can't open the second link, it says I don't have any permission for it.
But if it's still again asus or msi. Then I'd say they both are same but the msi is quite cheaper and has 12 gb ram which is more than enough. SO get the Msi.
ok, here is the stats for the second link, the asus.
Asus ROG G750JX-TB71 Notebook - 4th Generation (Haswell) Intel Core i7-4700HQ 2.4GHz, 16GB DDR3, 750GB HDD, 3GB Nvidia GTX770M, Blu-Ray, 17.3" Full HD Display, Windows 8 64-bit 1450
Get the msi laptop as it is much cheaper but has 12 gb ram which is more than enough 😀
the MSI is just 8mb
2.4GHz Intel Core i7-4700MQ (Haswell)
8GB of DDR3 1600MHZ RAM
1TB Hard Drive
17.3" Full HD Anti-Reflective Display
1920x1080 Resolution, 16:9 Aspect Ratio
NVIDIA Geforce GTX770M (3GB)
DVD SuperMulti Optical Drive
Integrated Webcam, Speakers and Mic
VGA, HDMI, and miniDisplayPort
Windows 8 Operating System
8 gb ram is enough to play games on ultra so that shouldn't be a problem. You can upgrade ram later if you want but you won't be needing to do so atleast not before next three years.
So msi is the one.
