Question need a need cpu heatsink and fan
markgraham312
44
Mine broke. I dont know what type of cooling fan/heatsink i need i have a asus P8B75-m mobo and an i5 proccessor please help me and link one that would fit
well right now its the only thing I can afford and I dont kn ow the make and model of the tower, but it seems to be the same size of the heatsink of the one that broke 92 mm. and the proc is an i5 3570K
how do i install this heatsink on my mobo? do i have to take the mobo out? or do i place the bracket onto the Proccessor?
You don't need to take the mobo out from the case, just lay it down, if the mobo have back plate or bracket it's more easy to install the heatsink rather than using push clip. If it using push clips, then you need to push the push clips really carefully and make sure it is in their hole, because sometime the push clips will be broken if you missplace it.
The way this aircooler mounts is pretty much the same way as the vast majority of other aircoolers on your board. Some have brackets that attach to the heatsink, some have brackets that just hold the heatsink down, but all have a backplate for weight support. Those that don't, use pushpin mount, same as that feeble stock Intel cooler.
You can use pretty much any aircooler you wish, if it has a 120mm fan it's going to be better than stock, if it's a known good brand name it'll for sure be better than stock. The only priorities are the case clearance and ability. Anything rated 130w+ and you are good to go.
Just avoid coolers rated for low profile as those are designed for htpc with minimal usage on cpus half of what yours can do.
CPU Cooler: ARCTIC - Freezer 13 36.4 CFM CPU Cooler ($31.33 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
CPU Cooler: ARCTIC - Freezer Xtreme Rev.2 Fluid Dynamic Bearing CPU Cooler ($33.89 @ OutletPC)
CPU Cooler: RAIJINTEK - AIDOS BLACK 48.6 CFM Sleeve Bearing CPU Cooler ($24.88 @ SuperBiiz)
CPU Cooler: RAIJINTEK - THEMIS 65.68 CFM Sleeve Bearing CPU Cooler ($33.15 @ SuperBiiz)
CPU Cooler: Thermaltake - Frio Silent 12 55.88 CFM CPU Cooler ($34.89 @ OutletPC)
CPU Cooler: Thermaltake - Frio Silent 14 71.23 CFM CPU Cooler ($33.40 @ OutletPC)
CPU Cooler: Deepcool - LUCIFER V2 81.33 CFM CPU Cooler ($34.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler ($29.89 @ OutletPC)
CPU Cooler: be quiet! - Pure Rock Slim 35.14 CFM CPU Cooler ($28.88 @ Amazon)
CPU Cooler: ARCTIC - Freezer 33 CPU Cooler ($29.89 @ OutletPC)
CPU Cooler: Deepcool - GAMMAXX 400 White 74.34 CFM CPU Cooler ($30.00 @ Amazon)
CPU Cooler: ARCTIC - Freezer 12 CO CPU Cooler ($25.99 @ Amazon)
CPU Cooler: ARCTIC - Freezer 34 eSports CPU Cooler ($34.99 @ Amazon)
CPU Cooler: Deepcool - GAMMAXX 400R 74.34 CFM CPU Cooler ($24.99 @ Amazon)
CPU Cooler: Deepcool - GAMMAXX 400 Blue 74.34 CFM CPU Cooler ($19.99 @ Amazon)
A good, cheap selection. See what fits.
Reactions: Mika-EL
