Need a new GPU cooling system
xzxjohnnyboyxzx
16
Hello :) So about 2 years ago i purchased a sapphire 7950 oc and today while cleaning i noticed that one of fans have stopped spinning. this is the second time this has happened! the first time i contacted sapphire and they sent me a new card (wasnt sure why considering a fan died). But it has happened again and have decided to get some form of an aftermarket Heat sink and fan for my card but i have little knowledge about aftermarket cooling for GPU's. So i was wondering if i could get some suggestions, but dont want to spend an arm and a leg on one. If someone could help and give me some options i would love you forever! Putting link to my specific card below.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202071
It is really designed to work with reference cards so any components that are too tall or moved might cause interference. Just a common issue I see in the reviews. I've not owned any of the high end Radeons lately, just a 6670 for an HTPC, so I don't think I can identify by site. Might check a website like EKWB to see if it is a reference design, they have a really comprehensive list of video cards, and what parts they have that fit them that you can use as a comparison.
G10 is basically guaranteed.
Only thing to worry about with the Artic Accelero are that they are really long and quite tall (three slots)
Visuals...
Almost too many options to list.
I used the old Accelero Hybrid to good effect. The new one has fitting issues with its full cover heatsink bracket. I prefer the NZXT G10 bracket plus a corsair H60 or similar, assuming you want to do closed loop cooling.
Arctic also makes several air coolers. Arctic Accelero Extreme series are huge coolers. Version 4 and 5 would probably fit the 7950, possibly 3.
Other options:
http://www.frozencpu.com/cat/l2/g40/c21/list/p1/Air_Cooling-VGA_HeatsinksCoolers.html
is there any definite way to make sure its going to fit/work? Do you now or previously owned this card?
also im not necessarily trying to have a closed loop set up. it can be just a normal shroud and heatsink i just need something that will keep it a tad cooler then what i have. money is tight right now on my end but i need something. if i fire up crysis 3 or dead rising 3 it ten mins im at 80 celcius.
Visuals:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186098&cm_re=arctic_accelero_xtreme_7970-_-35-186-098-_-Product
OpenBox:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186098R&cm_re=arctic_accelero_xtreme_7970-_-35-186-098R-_-Product
Cheaper cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186096
G10
http://www.newegg.com/Product/Product.aspx?Item=N82E16835146037
Arctic Accelero Hybrid:
