Need a small form factor VGA Card/Mobo
Savvy_01
113
More specifically, I need something that fits into the Inwin H-Frame Mini. Also, it must support a max resolution of at least 5760x1080 (triple monitors). I prefer fanless, but it fitting is the key concern.Thanks in advance for any help rendered
Not seeing any video cards that really meet your requirements that will fit in there. Low profile and single slot is a tough combination. And most don't have the real estate to support three video outputs. The ones that do are a bit specialized.
This card exceeds the included power supply of the InWin case but can handle 4 monitors.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131575
Only alternative is an Intel chip that supports 3 display outputs. Something like an i3-4160 since the power supply is rated for having a 65W CPU only.
Try it with this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128660
Sorry, I forgot. But no, i'm building a dedicated gaming rig for my tv (aka a steambox). This is only for work so just the monitors and youtube/internet. I was thinking of going with the A10-7850k, but I'm not sure the APU can handle the resolution.
