Hey guys,
I have a really big problem cooling my crossfired 4850's..
Ambient Room temp is around 75-80 degrees Farenheit.
I have one 120mm fan blowing directly on the top one and the second bottom one gets limited air circ.
I thought replacing the thermal grease with AS5 would help with the first one but it actually runs hotter by around 10 degrees Celcius! WTHECK!!!
I'm thinking about opening up the first one again.. maybe i didn't reseat it tight enough.
Currently on idle, and 0% GPU use, I'm reading 66 degrees C for the first and 53 degrees C for the second.
When gaming (GRID), I see artifacts and then the comp crashes and reboots. Pretty sure it's a heat issue.
I have:
1x 120 mm blowing air into the case for HD's from front
2x 120 mm blowing air into the case for CPU/1st 4850 from side
1x 120 mm blowing air into the case for CPU cooler from rear
For Pic:
http://www.abrahamchon.com/wp-content/gallery/crossfirex-setup/Computer%20through%20Side%20Panel.JPG
NOTE: the 2x 80mm on side have been swapped out for 2x 120mm
Any thoughts guys?
I have:
For Pic:
Any thoughts guys?
