[SOLVED] Need advice for memory upgrade on my MOBA (Kinda Urgent)
foreignsanxd
11
I currently have an B360M DS3H as motherboard with an I3 8100 and Gtx 1050TI, with 8 GB ram (Hyerx fury at 2400 mhz), I would like to add 16 GB of RAM in form of a 2 modules kit and also add an M.2 PCIe SSD.
My question is If I use 3 RAM modules at 8GB each at 2400 mhz would I benefit of triple channel?it can be diferent models of memory or it has to be the same? also I would like to know if my board has an M.2 PCIe slot?
hi,
memory only work in dual channel and must be same all the best solution is 2 x 16 or 2 x 8 gb of same memory...your mobo support DDR4 2666/2400/2133 MHz memory modules To support 2666 MHz or XMP memory, you must install an 8th Generation Intel® Core™ i7/i5 processor. U have 1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 SATA and PCIe x4/x2 SSD support)
hi,
