Need advice for my first build gaming & video rendering PC (appx $500 budget)
Jordant The
I need some advice for my build. This is my first time build my own PC and I will be using this PC mostly on gaming, video rendering, photoshop, after effects, and browsing. I need some comments from all of you. I accept all the advices and thank you for that.
Specs :
- AMD FX-8350 4.0GHz 8-Core Processor
- MSI 970 GAMING ATX AM3+ Motherboard
- Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory
- Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
- MSI Radeon R9 270 2GB TWIN FROZR Video Card
- Corsair Builder 500W 80+ Bronze Certified ATX Power Supply
I am sorry but low budget and professtional programs will do not go together well and that build will just take a long time to do anything fancy in AfterEffects and/or render anything over 100 frames long in at or higher than 720p
Looking at the build you had outlined, and not knowing any budget, I'd guess this would work fine for you. If you add a Hyper 212 EVO CPU cooler and overclock it you can squeeze some additional performance out of it:
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($159.99 @ Amazon)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($64.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($71.99 @ Newegg)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($74.97 @ OutletPC)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card ($139.99 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($34.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($13.99 @ Newegg)
Total: $577.90
Generated by PCPartPicker 2014-11-16 15:17 EST-0500
