Need advice for workstation budget build (~900$) for Solidworks 2018
BraveVN
7
I want to build a 900$ workstation (no monitor) to use with Solidworks 2018, mainly rendering & video editing. Below is the system requirement of Solidworks
Processor: Intel Core i7 or Xeon with high processor speed
Operating System: Windows 10 64-bit
Memory: 24GB or more
Hard Drive: Solid State Drive (SSD), maintaining at least 20GB free space
Graphics Card:
NVIDIA Quadro P600 (entry level), P1000/2000 (mid-range) or P4000 (high-end)
AMD Radeon Pro WX 3100 (entry level), WX 4100 (mid-range) or WX 5100 (high-end)
More detail about system requirements of Solidworks 2018 can be found here
According to the suggestion of Solidworks document above: The rebuild process in SOLIDWORKS is inherently linear (parent/child relationship of features) and therefore can only use a single core. and the Single thread CPU benchmarks, I choose i5-8600k for my rig, here's the full list of components, do you think that's good to go ?
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($239.00 @ Amazon)
CPU Cooler: Deepcool - GAMMAXX 400 74.3 CFM CPU Cooler ($23.79 @ Amazon)
Motherboard: MSI - B360M MORTAR Micro ATX LGA1151 Motherboard ($83.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (1 x 16GB) DDR4-2666 Memory ($144.99 @ Newegg)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive ($97.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: PNY - Quadro P600 2GB Video Card ($169.99 @ Amazon)
Case: Thermaltake - Versa N21 ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply ($51.65 @ Newegg)
Total: $886.27
From your own original post "Memory: 24GB or more". You are doing two things that hurt performance/stability IMO. You aren't using all the memory channels the CPU has by using a single DIMM and you may not be able to upgrade in the future without replacing the RAM you have. Mix-and-match RAM is always a gamble.
You also may want to look at this :
https://www.pugetsystems.com/labs/articles/Why-you-should-use-a-Quadro-video-card-in-Solidworks-2016-751/
you may also want to look into AMD Radeon Pro WX 3100 it maybe better than the P600 and only cost about $5 us more than the P600 on amazon right now but has twice the memory as 4GB.
32GB RAM is quite expensive these days, that's why I choose 16GB, I think I can upgrade later
btw, their minimum is 8GB
