hi guys, I need your advice, I can't decide which PS should I buy for the server mainboard, I found that at least I need 415W for running 32GB Ram and 2 Xeon E5450 Cpu. Here are the specs above...
What sort of PSU's do you have access to? You will need a PSU that can provide both an 8pin EPS as well as a 4pin EPS connector in order to hook up to the board, apart from the 24pin main connector. The connectors are mentioned in page 4~5 in their manual.
