Hello everyone, need a little help, I've had this gaming rig since march (GTX 760 ASUS, FX 8320, CM 412s, PSU Thermaltake Berlin 630W, Gigabyte 970A-UD3P mobo) and so far temperatures have been good enough, but I thought it was better to improve airflow in my Enermax Ostrog case. Went from
to
so I guess I have done a good job. (I had to push a bit the other side's panel to close it as some cables, mainly the 24pin one were kinda fat, also as you can see I've torn apart the heatsink from my ballistix elite to fit the cooler and just left the black pcb). Anything you would suggest to make this airflow better? Also, I really would like some tips about how many fans should I get. I currently have only one coolcox exhaust fan that came with the case and NOTHING else. I was thinking of getting a 120mm intake on the front, an exhaust on the top facing the RAM (but wouldn't that conflict with the cpu heatsink intake fan?) , an intake one near the exhaust one I just said to cool the heatsink even more (again, wouldn't that conflict with the exhaust I have on the back?) and an intake one on the left side to cool the gpu even more. Now, two of these fans (the ones up top) HAVE TO be blue-LED lit, don't care about the others. What would you suggest? I was thinking of the CM BladeMaster for the gpu-near intake one, absolutely no clue about led lit fans. Don't bother about silence or noise much, need high performance here.
Awaiting answers
Awaiting answers
