Need advice on build
dodron1324
72
Intel Core i5-4670K Processor - Quad Core, 6MB L3 Cache, 3.4GHz, 84W, Fan, 1200 MHz Graphics Core Speed - BX80646I54670K
Asus Z87-A Motherboard - ATX, LGA1150, Intel Z87 Express Chipset, 2800 MHz DDR3 (O.C.), SATA III (6Gb/s), 8-CH Audio, Gigabit LAN, Quad-GPU CrossFireX Ready - Z87-A
Patriot Viper Xtreme 4GB Desktop Memory Module - DDR3, 1600MHz, PC3-12800, CL 11, 1.5V - PX34G1600C11
WD Blue 1 TB Desktop Hard Drive, Solid Performance for Everyday Computing - 3.5" - Sata 6 Gb/s, 7200RPM, 64MB Cache, 2yr Warranty - WD10EZEX
Ultra Gladiator Mid-Tower Case - ATX/MicroATX, 3x 5.25" Bays, 3.5" Bays, 1x USB 3.0, 4x USB 2.0, 7x Expansion Slots, Black, Lifetime Warranty with Registration
Ultra LSP Series V2 650-Watt Power Supply - ATX, 6x SATA, 2x PCI-E, 20/24-PIN, Thermal Controlled,135mm Fan, Single +12V Rail, Short Circuit, Over-Voltage and
EVGA GeForce GTX 760 Video Card - 4GB GDDR5, PCI-Express 3.0 (x16), 1x Dual-Link DVI-D, 1x Dual-Link DVI-I, 1x HDMI, 1x DisplayPort, DirectX 11.1, SLI, Dual-Slot, ACX Cooler, - 04G-P4-3768-KR
Crucial M500 Series 240GB SSD - 2.5" Form Factor, SATA III, Encryption Technology, Advanced Controller Technology, Adaptive Thermal Protection
Did I read 4GB of RAM correctly (or 2x4GB). I'd absolutely get 8GB if you werent planning on it. Not too sure about "Ultra LPS" PSU...hopefully it's an OEM of a good manufacturer.
Its actually 2X4 that just didnt say it for some reason and as for tbe psu there actually isnt a manufacturer show on it, its in a bundle, so I may just replace it. Wasn't sure about how the whole build was, there was a combo with the same stuff with graphics card included that had an 850W psu so I wasn't sure 650 would suffice.
