Hello everyone,
I'm looking into building a nice gaming system that will be able to run Starcraft 2 at max settings and other new game releases and that can handle a lot of multi-tasking and 3D rendering (3d studio max, photoshop, etc). In the past I've always just bought a low-end computer and upgraded the things I needed, the computer I'm running at the moment is about 5 years old and everything inside it has been replaced over time aside from the motherboard and CPU. I've been reading a lot on this site and selecting pieces of hardware on newegg.com and I think I have a pretty good rig ready but I wanted to ask you guys your opinion (and to make sure I haven't paired up hardware that won't work with eachother lol). My biggest concern is the power consumption, I want the system to have enough juice to run everything without serious overkill or heat. At the moment I don't want to spend more than like $800-900 in total since it seems like I can make a pretty decent computer for that amount that will last a few years. I've always liked AMD and ATI over Intel and nVidia. This is the setup I have so far:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
$59.95
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
$109.99
Two of these for CrossFire:
SAPPHIRE 100277L Radeon HD 4770 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102835
$99.99 ($199.98 for CrossFire)
BFG Tech LS SERIES LS-550 550W Continuous @ 40°C ATX12V 2.3 / EPS12V 2.8 SLI Certified CrossFire Ready 80 PLUS Certified ... - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
$79.99
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136153
$25.99
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
$99.99
Logitech 967973-0403 Black PS/2 Standard Deluxe 250 Desktop - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126017
$12.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
$58.99
ASUS VW198T Black 19" 5ms Widescreen LCD Monitor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236032
$109.99
Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
$8.99
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
$41.99
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649
$139.00
Subtotal: $847.85
$59.95
$109.99
$79.99
$25.99
$99.99
$12.99
$58.99
$109.99
$8.99
$41.99
$139.00
Subtotal: $847.85
