Need advice on choosing a graphics card
pheonixkrish
26
Hello Folks,
Sweet day!
Need your advice on choosing a graphics card for My PC.
Below is my motherboard specification
OS Name Microsoft Windows 8 Pro
Version 6.2.9200 Build 9200
System Manufacturer INTEL_
Mother board Model : DH61WW__
System Type x64-based PC
Processor Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 3001 Mhz, 4 Core(s), 4 Logical
BIOS Version/Date Intel Corp. BEH6110H.86A.0044.2012.0531.1710, 5/31/2012
SMBIOS Version 2.6
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Name Base Board
Platform Role Workstation
PSU (SMPS) : 450 watts
Hard disk : 500 GB
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 3.90 GB
Available Physical Memory 2.52 GB
Please share your advice on choosing a best DDR5 graphics card within Rs, 15000
will my mother board support Asus NVIDIA GeForce GTX 660 2 GB GDDR5 Graphics Card ?
Should i need to update my RAM and PSU to use this card ?
If yes, Please guide me on choosing a suitable SMPS for my PC.
Your advice is much appreciated.. :)
well, both cards will do great on that screen. the GTX 660 will be slightly more powerful. but the 750ti will do about as well. with that power supply a 750ti is a better idea, as 450 is the minimum recommend by nvidia for the 660.
that is a pretty good CPU, it real weakness is the lack of RAM. I would try to get 2 4 GB sticks to replace the 2 GB sticks I think you have. the issue is, is that it appears you have a 32 bit OS, so you cannot get above 4 GB, so you might want to invest in a 64 bit OS. A 660 will want more power than that power supply can give. for a 660 I would say around 550 watts. I'll go post some power supply ideas.
Hi Robert,
Thanks for your advice
Will update my PC's RAM and PSU as per your advice.
Actually My monitor's resolution is just "1366 X 768".
So, Will it be ok to prefer Asus Nvidia GTX 750 ti 2 GB OC edition depending on My screen resolution?
I'm little confused here :??:
I need to know which card is best for my screen?
Is it Asus Nvidia GTX 750 ti 2 GB OC (or) Asus NVIDIA GeForce GTX 660 2 GB GDDR5 ?
Please share your thoughts and advice.
Awaiting your response.
