Need advice on good sub-$40 CPU Cooler
Jagwar8
80
Hi all,
I am looking to OC my FX-6300 to around 4.3-4.6 ghz max to help a bottleneck. The issue is that my case (Cougar MX-200) does not support many coolers. I would like to find a sub $40 am3+ cpu cooler that would be able to dissipate that heat and yet not be too loud. Easy installation would be great but not an absolute necessity. Any advice?
For a normal cooler, I would suggest a Cryorig H7 or a Hyper 212, but if clearance is an issue, you better fare with a Cooler Master T4. If the front intake fan is stock, then changing it for something airflow optimized is going to benefit your temps, unless you're taking off the side panel.
Mohd Mamat
538
