I have recently ditched Comcast 100 Mbps service and upgraded to AT&T Gigabit fiber. My current home network is not really up to the task and never has been great since I moved into this house about five years ago. I'm hoping to get some suggestions on an optimal setup along with equipment ideas.
I've included links to my floor plan:
This house is an old ranch style home. The basement buildout is fairly new however.
I have an Arris BGW210 provided by AT&T at one end of the house on the main level. The room it is in is directly above an unfinished storage area in the basement, a portion of which is completely encased in cinder blocks (weird I know). I have run CAT5 from the Arris into my office in the basement that is on that same side of the house (though closer to the center). This CAT5 runs into a Netgear R6400. I have the following equipment hardwired via 8 port TP-Link switch:
Once I installed Gigabit and the Arris, I've experimented with the following setups:
Here's what I am seeing speedwise throughout the house:
I'm wondering about the following setups:
Love to get input on how I should be thinking about this. Or maybe I'm overthinking this. Thanks!
- Synology NAS
- Arlo camera base
- Samsung Smartthings hub
- Wireless printer (room next to router)
- Roku TV (room next to router about 40-50 ft away)
- nVidia Shield (room at the other end of the basement)
- 3 laptops
- TV w Chromecast (other end of the house from the Arris)
- 2 laptops
- Arris set to IP Passthrough and connected via Ethernet to R6400 which provides 2.5Ghz and 5Ghz networks. Didn't get great results this way.
- I've now set up the Arris as the router and a 5Ghz network and have set the R6400 as an AP w a 5Ghz network (I had to ditch the 2.5Ghz as I discovered the Arlo base was causing major interference). Much better results, which is not really what I expected. Initially I saw problems w the Arris 5Ghz interfering w the R6400 5Ghz but changed the channel on one and now don't see any problems.
- 350-500 Mbps on a MBA sitting next to R6400.
- 75-200 Mbps on the nVidia Shield at the other end of the basement
- < 25 Mbps most places upstairs except for in the room w the Arris.
- Eero Pro (3 pack) with one connected to Arris, 2nd one where R6400 is connected to the first one via CAT5, and 3rd one upstairs halfway to the other end of the house.
- Similar setup with Google Nest (1 router and 2 AP)
- Unifi Dream Machine in basement where R6400 is, connected via CAT5 to Arris and a UniFi FlexHD AP upstairs.
