I've recently been thinking on upgrading my Prebuilt Gateway desktop (DX4380). This is the first time I've done this so I appreciate the help ![Smile :) :)](/data/assets/smilies/smile.gif)
Anyways I'm gonna be upgrading the PSU and GPU and maybe the fan. I'm not planning on buying high end stuff so I am on a budget. But I'm not super picky when it comes to hardware, just something that can get me by.
My current specs are: 8 GB RAM
Quad-core A8-6500 APU - 3.5ghz
AMD Radeon HD 8570D
300W PSU
Windows 8.1 64bit
I want to get an R7 260x as it's pretty decent being so cheap, If you guys have any other suggestions feel free to give me a suggestion. Although I'm not sure what psu I should get as I don't know which will fit inside my PC. Is there a way to tell or will most of them generally fit inside what ever medium sized pc there is? Other than that, Id' be fine with 600W or around there.
Also the fan. Not sure whether or not it'd be worth it. I'm afraid it'll get too hot with just my regular PC fans so I'll be willing to buy a fan if necessary.
Thanks again.![Smile :) :)](/data/assets/smilies/smile.gif)
AMD Radeon HD 8570D
300W PSU
Windows 8.1 64bit
Thanks again.
