I have an old PC which I'm refurbing to run Windows XP Pro x64 and some older XP software that I still like using. It runs a bit slow and I'm wondering if replacing the CPU would be worth the cost or effort.
I don't know a whole lot about comparing processor performance and I'm wondering how the one I have compares to others on the list of supported CPUs, or if it would be worth the money to get a different one.
Most of the old programs are likely single thread and don't need multi core CPUs. Things like Paint Shop Pro 5 and Print Shop Ensemble III. The most CPU intensive would probably be and old version of Punch Pro Home Design, but some extra speed in rendering would make them much nicer to use, as well as more speed in saving and transferring large numbers of backup files from drive to drive.
The motherboard is a Biostar MCP6PB M2+ 6.0, with a pair of 4GB, G.Skill DDR2-PC2-6400 Ram sticks (Model F2-6400CL5D-4GBPQ)
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=387#cpusupport
The current CPU is an AMD Athlon 64x2 Dual 4400+ (2.31 GHz)
Can anyone tell me if there are others on the list that would be significantly better. I looked on NewEgg and found prices on some of them in the $25 - $50 range (several are "refurbished" though)
So, any advice would be very helpful and very much appreciated.
Thanks,
John
Thanks,
John
