I have the means of upgrade a component on my system but am unsure of which will show the biggest change. The current setup is:
Intel i7-7700K
Zotac 1080 Amp Extreme
16GB G. Skills RGB 3200
240GB M.2 BPX, 3TB HDD, 1GB SSD Crucial
Thermaltake RIING 240 Watercooler
Thermaltake Toughpower Grand 650W PSU
Thermaltake Overseer Full Case
Acer Predator XB271HU
Asrock Z170 OC Formula
Various fans throughout
Oculus Rift setup
I could upgrade the GPU, or the CPU, or any of the others. I just dont know which would show the best results. If I were to upgrade to a 1080ti or upgrade the i7 to a higher one or even preorder one of the lower i9s they have coming out. I could tidy up the hard drives/ssds and get a 2tb ssd, but no improvement performance wise and they get ridiculous after 1TB, plus I dont need to.
The PSU appears as if it is low watts, but I rarely reach half of the watts and normally rest at 170W usage, according to the monitor my UPS came with. I could upgrade motherboard but would have to make sure most, if not all parts are compatible for the switch plus figure out if that would give any performance improvements or does it just provide the current port capabilities for todays parts.
So, I'd at least like to think I have a decent setup, on a decent setup what can be upgraded for best noticeable results?
Intel i7-7700K
Oculus Rift setup
