Need advice: Taped backglass artwork
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I have a very nice '77 Gottlieb backglass. The bottom 4" of the glass has
been touched up (very well, I might add), and covered with something that
looks like clear packing tape. It looks like the rest of the glass has had a
thin layer of triple-thick, but I'm adding another coat for good measure.
Any advice on what to do with the clear tape? I know I should leave it in
place, but should I triple-thick over it too? Also, should I expect that
it's only a matter of time before the tape comes up, taking the ink with it?
So far it's holding just fine.
John
G
Guest
Guest
Nevermind... I found some good posts on Google, and decided to leave the
taped area alone.
John
"John Schlarb" <john@schlarb.com> wrote in message
news:S9Xze.35779$B_3.9339@fe05.lga...
>a thin layer of triple-thick, but I'm adding another coat for good measure.
> it? So far it's holding just fine.
> John
