Need Advise on Case Air Flow.
Alpha-Black
462
Hi
i have a Gigabyte sumo Alpha case and it has a big 12X10 inch Steel mesh on the side panel.
[/url][/img]
and i flipped all my fans as intakes coz i think this the only way to make a positive air flow inside the case coz mesh is a big hole to for frequent exhaust.
[/url][/img]
now do i have a positive air flow or in need fan for exhaust also.
actually from the PCI cover area and mash is just exhausting cooler air also there is no hot air at all coming out of any side of the case.
Advise rather its on or do I need to do some modifications
Thanks
Change those fans! your system will thank you.
Top and rear should be exhaust. Front and bottom should be intake.
Positive pressure does not matter anymore like it used to. You system will stay cooler if you flip the fans so the top and rear are exhausts.
