Hello there!
I've got a new gaming pc since a few months.
In the beginning I found out that it was getting too hot, so I placed 2 intake fans.
I still think that the pc is getting too much heat and that I can make it much more cooler. I think turning the PSU or changing the outtake fan would lower the temperature.
For my intake fan, I've bought 2 of these:
https://www.bol.com/nl/p/scythe-slip-stream-120-mm-slim-case-fan/9200000010965019/?suggestionType=typedsearch
[img=100,100]https://i.imgur.com/9pfW97M.jpg[/img]
Due the size of the case, I could only take 120 mm slim fans, because the standard 120 mm fans were too thick.
[img=100,100]https://i.imgur.com/t7gepXA.jpg[/img]
The pc has been assembled by a shop. I however do not get yet why the fan is on the inside, while there is a hole downward, so the PSU could be turned, which looks more effective to me.
[img=100,100]https://i.imgur.com/tH2NW9T.jpg[/img]
As outtake I've this fan which was delivered with the case purchase. I believe it's a 120 mm but I'm not sure. I've the feeling the fan isn't getting much air out, mostly due the lack of space behind the case, but still think that another would be much more effective.
[img=100,100]https://i.imgur.com/NyNiNrk.jpg[/img]
Would it be advised to change this fan for a High Airflow or Static Pressure fan ? I think this one is a Static Pressure? and that a High Airflow might be better? But then we still got the lack of space behind, which won't change.
So this is my setup atm. I'm very curious to what I could do (Except moving case) to increase my cooling. I think that changing the outtake fan to a better one that can do more, would be a big increase. Also, turning the PSU might help I assume?
Thanks anyways for reading this far and I'm looking forward to the comments
