Need build advice
Pixelatedtrollface
195
Approximate Purchase Date: e.g.: 5-6 Months (Haven't saved up enough yet)
Budget Range: $300-500 After Rebates; After Shipping; With Monitor & OS
System Usage from Most to Least Important: Gaming, Skype Calls, surfing the web & watching youtube vids
Are you buying a monitor: Yes
Parts to Upgrade: CPU, GPU
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Anything a lot of people use (Newegg, Ncix, Amazon, etc)
Parts Preferences:
- Windows 8.1
- Pentium G3258 (Or another LGA1150)
Overclocking: Most likely
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: I would like to have a window, but its fine if you can't get one in the small budget, I would also like it to be small (mATX), and somewhat quiet, also prefferably Z87 or Z97.
Thanks for helping,
Pixelatedtrollface
Honestly it doesn't make any sense at all to choose parts now, in 2 months already prices will be way different to what currently they are, better ask the question again in 6 months when you have the money.
Only thing I could add here, if you plan to eventually do SLI/Crossfire, most likely you'll need a bigger case than a a mATX case. (even for a single graphics card a mATX might not be enough depending which GPU is bought).
