G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Looking for an ATX case under $75 or so, for a Biostar M7VIG system
which will get heavy use as an internet-surfing machine and nothing
else.
It's for a girlfiiend with specific tastes in home furnishiing -- Need
simple design with an offbeat color.
I've never had to choose a case where things like color are an issue,
so I'm on unfamiliar turf.
Two boxes which I think would visually appeal to her are:
Evercase GC4292 -- would probably be her first choice, but I can't
find any reviews on it
http://www.newegg.com/app/ViewProductDesc.asp?description=11-127-032&depa=1
and
Chieftec CX-01 BL-BL-BLK
http://www.newegg.com/app/viewProductDesc.asp?description=11-125-712&depa=0
which from the Newegg reviews in other colors seems to be OK, though I
wonder about the sturdyness of the hinge on the bezel door.
Any experience with either of these cases from a building standpoint?
Any recommendations for something visually similar which is also a
better case?
else.
and
better case?
