[SOLVED] Need CPU/Motherboard advice
Greeny962
I have an HP 410-017C:
Shave-HSW(Pegatron IPM81-SV)
I3-4170
1TB WD Blue SSD
16GB 1600ram
350w MIPC sx6350 PSU
Gigabyte GeForce GTX 1650OC, low profile d6
I was told that the i7-4790k would work with this board. I updated the bios, installed the CPU and got an unsupported CPU error. It did recognize the CPU and displayed the correct information, but it says it’s unsupported. I put the i3-4170 back in and it booted back up fine .
My question is: Is there a different bios update I can flash to run this CPU on this board or do I need to upgrade the board? If I need to upgrade the board, any advice on a microATX board for this SFF system?
Thanks in advance.
Core i5-4460T is the only other CPU supoorted by that MOBO according to HP doccumentation.
Also the max TDP for that MOBO is 54W the i7-4790k is 88W.
CPU supported:
Processor​
TDP​
Integrated Graphics​
Intel Core i5-4460T (Haswell) 1.9 GHz Quad Core​
35 W​
Intel HD Graphics 4600 (GT2)​
Intel Core i3-4170 (Haswell) 3.7 GHz Dual Core​
54 W​
Intel HD Graphics 4400​
