Approximate Purchase Date: Around black Friday or later if the prices could get better in the future I'm not if sure they will though
Budget Range: $1000 excluding peripherals and windows and monitor
System Usage from Most to Least Important: Gaming - using the internet for schoolwork
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: whatevers cheaper. I have a micro center store close by as well.
Parts Preferences: I don't care as long as it lasts and its fast and cheap
Overclocking: no cause I want pc to last long. It will probably go years without an upgrade.
SLI or Crossfire: i don't know what this is
Your Monitor Resolution:1920x1080 but I want some decent hertz with the monitor
Additional Comments: I'm broke so if there's any tips on saving money on parts without sacrificing too much performance id appreciate
Additional Comments: my friend gave me his extra fan cooler thingy I'm not sure if this is the exact one but it's from NZXT and looks just like this https://www.amazon.com/NZXT-Kraken-280mm-All-One/dp/B06XX8Q1CL I don't know how to use it though
