I could have sworn my ATI9800pro AIW had one DVI and one VGA connector. So i bought my 2 widescreen LCDs assuming I could use them.
Unfortunately this is not the case as it only has one DVI so I need ot get a dual dvi card asap (if im buying a card specifically for this theres no point in getting vga/dvi)
I like to play FPS games such as CS, BF, BF2 etc and would like to be capable of playing anything on the shelf right now but im not a serious gamer by any means. Watch a lot of movies on my PC, make movies, some web/graphics work etc....
My mobo right now only supports AGP so while I have not completely ruled out a enw mobo/cpu combo at this time that would give me PCI-E, I would like to stay away from spending more money if possible.
so...
1. What card woudl you reccomend for AGP?
2. What card for PCI-E
3. Would I be paying less money for a superior card if I was buying for PCI-E? (could help rationalize the purchase of the new mobo.
This is the only "reasonable priced" one i have found....but i dont know hwo good/compatible it is:
http://www.newegg.com/Product/Product.asp?Item=N82E16814150096
thanks!
so...
thanks!
