Need first PC advice
Agathor
Commendable
Aug 23, 2016
163
17
I haven't got a huge budget and I really want a decent gaming rig. So do I get a i3 4170 and gtx 750 ti now and upgrade GPU later, or get g3258 and gtx 950 and upgrade CPU later? Or consider AMD?
logainofhades
You will want a current gen setup. You can upgrade storage and such later.
CPU: Intel Core i3-6100T 3.2GHz Dual-Core Processor (£91.10 @ Amazon UK)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard (£48.99 @ Amazon UK)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory (£21.55 @ Amazon UK)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive (£18.20 @ Amazon UK)
Video Card: Asus GeForce GTX 950 2GB Video Card (£124.96 @ CCL Computers)
Case: Xigmatek Aeos MicroATX Mid Tower Case (£23.99 @ Overclockers.co.uk)
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply (£36.22 @ More Computers)
Total: £365.01
Generated by PCPartPicker 2016-08-23 17:44 BST+0100
logainofhades
Total: £365.01
logainofhades
Looks like the price went up, on that ram. That is the one thing I do not like about Amazon. Their prices fluctuate way too much. This is the closest I could find, price wise, for 8gb. While you lose some performance, going with single channel memory, it will allow you to go to 16b, later on, without having to buy a brand new 16gb kit. Just buy a matching stick later.
https://www.amazon.co.uk/dp/B00MMLUYVU/?tag=pcp0f-21
Agathor
Commendable
Aug 23, 2016
163
17
Thank you, that brings it back into the price range. Will i need a wireless adaptor (can't use ethernet cable) or does this motherboard already have a wifi thing?
