Hi Folks,
I have a Dell Optiplex 7040 Micro form compuer I purchased. It did not come with a factory installed WiFi Network Card.
Dell recommends using the Intel AC-8260 Wireless Card, it is a Dual Band Card. I intend to purchase this card.
My Optiplex has no existing internal Antenna but does have a hole for SMA antenna on the back.
Q1) Do I need 2 Antenna's (SMA or Internal) attached to both connector of the WiFi card to utilise the Dual Band Wifi network? That is, will I be able to use Dual Band with only 1 antenna?
Q2) If I decided to connect with Internal IPEX MHF4 antenna's (using both - as they seem to be sold in pairs), where would be the best place within the computer's Chassis / Case to place the Antenna's?
I'm new to this Higher Level of I.T. and would really appreciate any help from folks who understand this level of detail.
Thank you in advance
Cheers
Cheers
