Need Help About My GFX Card
Evan Gibbard
135
Hey everyone i ask on the fourms yesterday and everyone said i was bottlenecking but i dont know i called up my local Comp shop and they said i wasn't bottelnecking
Here are my main spec:
http://imgur.com/tSQOLKX
So yeah and for some unknow reason i cant get shadow play when i have a better amd then what it says s i dont know if anyone could help me and i would like to know which amd to upgrade so i dont bottelneck anymore.
have the FM2 socket and would like to know which one to upgrade to i dont wanna go intel or have to buy a AM3 mother board.
Thanks for the help and fast replys
yeah okay ill just play a ton of games and that for about a week then OC thanks do i have to buy more Compand or does it come pre installed and how do i wash of the old compand from the CPU cooler
yeh and any suggestion on how much i should OC it to
It's different for every card. Install it and run Prime95 for a couple hours and I can give you an estimate, but case ventilation, your cooler, thermal paste, ambient temperature, dust, are all factors. Won't know what you can do until you get numbers.
Okay thanks so much guys for the help but is there anyway i can get fps before i buy a new cpu or to help with a bottelneck
When running P95 keep a close eye on your CPU temp using coretemp
It's an artificial load that will rarely happen in the real world, so you can expect your load temperatures to be lower with your overclock
I don't think so, an overclock on your 660 using Afterburner might yield some results
Okay thanks so much for a quick reply and all your help really happy with how nice you guys where
