Need help about QOS
mohsen gtx
112
Hello guys , i have a router in my home and there is 3 PC connected via wifi to this router .
one of them playing games online and the bandwidth is very very low for me !!
so i want to learn how can i config the qos to set the priority for me .
please help me and thanks
You are extremely limited because you have a dsl modem in your device. There are tplink models that have much better qos I just do not know which. Look at the online manuals. You will need to be able to restrict the data rates to a fixed value for particular IP addresses on the download rates.
Unless there are more advanced QoS screens in that router you are wasting your time. That is a very fancy screen with lots of options that do absolutely nothing on a internet connected router.
Most routers like this can only partially limited upload traffic and it is highly likely your problem is on the download side.
Also remember if you were to get a different router that can limit download traffic setting stuff up so you get better performance means someone else gets worse performance. If you pay for the internet connection then you get to make the rules but when it is not that simple you need to get some kind of agreement. You technically could solve your problem by yelling down the hall get off the internet I want to play my game.
