Question NEED HELP ASAP
jasonbrownlee2003
Commendable
Jan 28, 2018
62
Hi, my PC used to run perfectly fine on wireless connection but recently it’s been slow to the point it won’t even load Googled homepage , my internet is rated at 58Mbps which I get on my phone and iPad in the same room but the computer doesn’t.
How do I fix this ASAP because I can’t even use basic functions on the computer now!
Would you please run a Speccy Scan and, after having done so, post the snapshot link in your next reply?:
Using Piriform’s Speccy to Collect Your Computer’s Hardware & Software Specifications & Report Them to an Assistant
1. Go to the Piriform Speccy Download Page and download the program.
2. Run the installer you’ve just downloaded or unzip the ZIP file if you prefer to use the portable version.
a. If you choose to run the installer - Note: The Speccy free installer may now come with Avast and the Google Chrome browser bundled with it (or something else, what’s bundled has changed over time). Make sure that you UNCHECK the options to install any bundled software when you see the checkboxes during the Speccy install sequence. When you reach the end, uncheck the View Release Notes checkbox, then activate the Run Speccy button.
b. If you go with the portable version just fire up Speccy from the unzipped folder location.
Regardless of which method you choose, you will be presented the Speccy Main Window:
3. From the File Menu, activate the “Publish Snapshot” item [or press ALT+F,B]:
4. You will now be presented with the Publish Snapshot Dialog:
You will, of course, activate the Yes button.
5. Finally, you will be presented with the Snapshot URL Dialog:
on which you will activate the Copy to Clipboard button so that you will have the snapshot web address to paste into your message.
Note: If you want to save your system specs to a text file, at step 3 choose the Save as Text File option at step 3. This can be handy if you need to e-mail your specs.
Okay will do, But may i ask why would you need a spec list of my computer. Could you enquire specification information you need as i can publish those instead of everything as i know there will be some sensetive info being displayed on speccy :)
